weird wiring issue
AF_Hemi
Central Jersey in person, the burgh at heart
2013 Ram 1500 CC 4x4 Sport
Hey all,
During the stereo installation i left the battery hooked up simply put cause i was too lazy to unhook it and i was careful to not fry anything. anyway, since the doors were open for extended periods of time, the truck often went into sleep mode. Now that I have everything back together and everything plugged back in, it still acts like its in sleep mode all the time.
When the doors open, the dome lights dont come on, the headlights wont come on unless the key is in, the power door locks dont work, and keyless entry doesnt work either. This is just what i've noticed so far -- mostly because it was dark.
Any ideas?
AWE Daniel
Banned
I would unplug the batt, leave it like that awhile
AWE Daniel
Banned
Yeah Hopefully, if it doesnt work then you can start checkin fuses and relays
glass3222
Central PA
I would try a hard reset. Unplug the positive terminal and tough it to the still connected negative terminal for 30-60 seconds.
RubberFrog
I am going to bet that you blew your accessory power fuse. Now you know, ALWAYS unplug the batt, even if you're being careful.
glass3222
Central PA
If your fuses are all good, you may need to get your PCM re-flashed at a dealer. I know that is probably a last resort for you, but that is all I can think of.
SMKN
Waynesville, NC
Have you tried the roller switch on the headlight assembly, maybe you shut it off by accident, although that would not affect you keyless entry and door locks.
I don't know man!
RubberFrog
Exactly. You gotta test them. I am certain he blew a fuse.
AF_Hemi
AF_Hemi
Fixed the issue. There are 2 constant 12v wires in the wiring harness for the head unit. the guy at tech support said i only needed to connect one. he was dead wrong. i reconnected that wire and everything came to life. problems fixed
AWE Daniel
Banned
glad you got it worked out that was a weird one
SilentRamAD
Cypress, CA
08 QCSB 2wd
287 4.7L
Problem Solved. Grats ! Haha a simple wire "said" to not be "needed". Priceless
Off Topic: White trucks not in the white truck club *tear*
joshhhh
