What fuses control the a/c compressor?
brc19761
South Mississippi
5.7l Hemi
Hi, I have a 2wd 2011 Ram 1500 crew cab with the 5.7 hemi, and only 87,000 mile on it. The a/c has always blown snowballs and never had any issue with it. I drove the truck this Saturday and the a/c worked great. I get in the truck today (Monday), and the compressor doesn't even come on. It blows hot air and the a/c compressor will not cut on. I read all the fuse locations under the hood and I could not find a fuse for the a/c compressor. I only found fused that inticated hvac front and rear. It either has to be an electrical issue or perhaps the freon is low. The compressor does not kick in and the a/c lines do not get cool or cold under the hood. I just can't seem to find which fuses I need to pull to see if any are blown. Any comments or advice is greatly appreciated.
turkeybird56
Central Texas
turkeybird56
Central Texas
OP look in yer manual for AC clutch fuse see if something like that listed also.
turkeybird56
Central Texas
On newer rams there is 40 amp cartridge fuse also do not know on .2014.
B
brc19761
South Mississippi
5.7l Hemi
Thanks for the video links and the replies. Looks like it is not just a simple blown fuse.
You think it might be the switch on the dashboard that turns the a/c on and off?
turkeybird56
Central Texas
Honestly do not know, but if it worked one moment, not the next, nah, not think so.
Reminds me of the old Thermo Coupler fuse that used to be in powerline right where they plugged into the Compressors on the Older Delco (GM) and Chrysler compressors. I do not know if they even still use a thermo coupler on Compressors: (Now think all run by TIPM/BCM. Not sure on 2014, prob TIPM tho) U R way outta my comfort zone/knowledge on this subject). SOMEBODY who knows more needs to Chime in.
But FYI: There are still thermo coupler type fuses on household dryers.
I WOULD still research and see if there is still the AC clutch or whateva called now similar fuse.
turkeybird56
Central Texas
HERE U GO OP: This is from a 2013 Manual: Prob same on yer 2014:
Check out this fuse as indicated: AC Clutch: I would look at old fuse, and put in a Brand new one and see what happens: MAKE sure your AC is not turned on when U do this FUSE. Best I can do for you.
PVilefort
HOUSTON, TEXAS
3.6L V-6
On a 2021 RAM 1500 Classic Tradesman 3.6L V-6 automatic the AC clutch is listed as a 10 Amp Red fuse. I am surprised it id so low, but that is what is listed. On my truck it is in the F62 cavity.
PVilefort
HOUSTON, TEXAS
3.6L V-6
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
If the fuses are good and it just stopped working, look into having the refrigerant charge checked. No refrigerant, no cooling. Also could be a bad electric clutch...
Two interlocks will lock out the compressor:
1. Low refrigerant (caused by a gas leak / low charge)
2. High refrigerant pressure (caused by blocked air flow on the condenser ((radiator)) ).
noraa73
