what is the best delete kit for the money?
wellswood798
west lafayette, indiana
Hello and thanks for the add to new group! I have a 2016 ram 6.7 diesel all stock I would like to do full delete on wanting to no from the group what to look for or avoid in the kit thanks in advance.
MADDOG
Living in a Firepit
6.4L HEMI
When I went looking for a "kit" I found out that there wasn't a total package available.
Rather, shops would put together a package to do a full delete including the EGR, throttle valve, EGR cooler, the DPF catalyst chamber/exhaust cannisters, a programmer with tunes and a pipe kit to replace those exhaust components.
So I had a local shop put together their list of components and I went with their recommendations. Here is the list as was installed on my truck:
Delete & Tune mods
Edge CTS-2 Insight monitor with Cummins unlock
13 – 17 EFI Live Dodge CSP4 tune package by PPEI / Kory Willis
13 – 17 EFI Live Dodge transmission tuning
Cummins tuning switch CSP4
EGR valve and cooler removal with block off plate​
Throttle valve delete​
Edge expandable EGT probe kit
Pillar pod mount for Edge CTS2​
Transmission mods
BD Diesel 68RFE valve body plate kit
Mag Hytec deep transmission pan
ATS 68RFE transmission case support brace​
Exhaust Upgrade
FloPro 4“ cat & DPF cannister delete pipe
4” – 6” black exhaust tip with rolled edge
Corsa 8004002 4” muffler – placed just downstream of down pipe​
McBroom
Denison Tx
Hemi 6.4L
Delete & Tune mods
Transmission mods
Exhaust Upgrade
Why is this in the detailing section?
Black 20 Ram
MADDOG
Living in a Firepit
6.4L HEMI
It's not in the Detailing section anymore.
I moved it last night from Detailing to the Cummins section, 6.7L Common Rail about the time I posted up my delete info.
tigerl0128
Columbus Ohio
Delete & Tune mods
Edge CTS-2 Insight monitor with Cummins unlock​
13 – 17 EFI Live Dodge CSP4 tune package by PPEI / Kory Willis​
13 – 17 EFI Live Dodge transmission tuning​
Cummins tuning switch CSP4​
Edge expandable EGT probe kit​
Transmission mods
BD Diesel 68RFE valve body plate kit​
Mag Hytec deep transmission pan​
Exhaust Upgrade
FloPro 4“ cat & DPF cannister delete pipe​
4” – 6” black exhaust tip with rolled edge​
I am new to owning a diesel and came across this while looking for recommendations on a delete kit. Do you mind me asking what this cost you? I understand this was posted in 2020 and prices have gone through the roof since
dakota18
