What is the reliability of the rear end?
FullForceRam
Brentwood, Ca
5.7 Hemi 2WD Quad Cab
Recently purchased a 08' Ram with the 5.7
I'm not certain of the rear end ratio, but I'm pretty sure its stock.
I tow a 2400lbs single axle enclosed trailer a few times a month and I ask what the reliability is of the Gen3 rear end and its planetary, pinion, spider gears are?
I owned a 02' with a 360 5.9 and I ended up replacing the planetary, spider, and pinion gears once before, not sure if dodge stepped it up with stronger components for the 08' with the Hemi.
Any info would be great.
Thanks,
-Sam
usaf2006
North Carolina
As long as you change the fluid at regular intervals as need, it should be okay. Especially since you're only towing about a third of the max towing capability.
FullForceRam
FullForceRam
Brentwood, Ca
I'm always good at keeping records and maintaining fluid changes on our vehicles, was just wondering if they had changed or upgraded the rear dif gearing.
Thanks!
SilverStreak88
Houston, Texas
5.7 Eco Gasser
As already stated, keep the maintenance up and you're good, you've probably got 3.92 with an LSD.
