What is this connector under steering wheel for?
SavedByGrace
California
5.2 Laramie
Found this hanging and trying to track ABS light and brake light issue. never had this until i swapped to 05 ecm.. (Do i need to calibrate something? i cleared ABS codes with scan tool but light is still on). My cruise control is also acting wierd, i removed the switches and they send thru a signal when pressed). Also tested the ribbon inside the clock spring and all teminals have perfect continuity. Radio and vol buttons work perfectly.
SavedByGrace
SavedByGrace
California
5.2 Laramie
After doing more digging I found another posted witha different issue but in his pic it appears this connector is not used? See beloow the yellow circle-
OasisNinjaBat
