What is this tool for?
4xdad
Edmonton Alberta
2015 powerwagon
I turfed my stock jack and made a spare tire carrier I got a 75 ton high lift hydraulic jack it’s way over kill but it was on sale lol I plan to put a spare fuel tank in the spot where the tire used to go
Fediej
Wisconsin
EcoDiesel
When I had my 1980 Sachs moped, the tool pouch included that exact thing. It was for the spark plug.
62Blazer
Midwest
While I agree it is a spark plug removal too, I'm pretty sure it is NOT something that came from the factory in a Ram truck. Most likely the previous owner had it because of some type of motorcycle, ATV, or some other machine with a small gas engine (i.e. chain saw, mower, etc...) they regularly had in the bed of the truck. While having to pull and change spark plugs on small engines is pretty common, it is in no way common to have to randomly pull spark plugs on a newer vehicle for any reason....definitely not common enough for the factory to include a tool in the truck.
Hemi832
Houston
Those are also used on chainsaws to adjust the chains/ sparkplug/ taking the bar off.
4xdad
Edmonton Alberta
2015 powerwagon
Seems to be a little confusion about how to lower the spare tire you use the jack handle inserted into the bumper and lined up on the winch they get rusty and can be apita
Spree
Indiana
Spark plug wrench for a motorcycle. My plugs are deep in the cylinder.
4xdad
Edmonton Alberta
2015 powerwagon
Drop it before you need it and lube that sucker up it’s one of the reason I built my tire carrier
4xdad
Edmonton Alberta
2015 powerwagon
Pics of where to stick the jack handle
NASCAR
Calif.
Diesel 6.7L Turbo
That’s not strong enough to loosen tight lug nuts. I have owned a lot of different vehicles and never had this in the tool kit. I believe it was left in the vehicle from someone that either had a motorcycle or lawnmower or some other gas powered yard tool.
62Blazer
Midwest
Yep. I want to see somebody try to take off a lug nut torqued to 130 ft-lbs. with something like that! Even if a person was strong enough a tool like that would fold in half before the lug nut moved.
Orca
