What spark plug wires and dist. cap work good on a 318
fonzyn75
hey guys just wondering if anyone knows what type of spark plug wires and distributor cap works good with a 2000 ram 318.
WhiteExpress
Midland, TX
Go to Napa, get the Echlin Cap and Rotor (the brass contacts) and the Beldin Wires (expensive ones). I've run that setup on like 10+ Magnums for the longest time without any issue.
You don't need 8MM+ wires unless you're running a hot ignition coil etc. Just stick with the factory 7MM so the wire looms still fit. Make sure you use them too, these motors will get a crossfire between the plug wires if routed wrong.
ameer73
