Wheel Lock for 2020 1500 Laramie Night
Randon1981
Sugar Land, TX
I'm needing to change my tires on my 2020 1500 Laramie Night, but I guess I didn't get a key to unlock my wheels. It's nowhere to be found in my truck. Does anyone know where I can get one and how to know which key to get?
British Bulldog
Jacksonville NC
SST HO
The service dept of dealership should be able to help. They should be able to tell you the code if it was bought local. Failing that, they also may keep some keys that are able to help. We did at theFord garage I worked at. Failing that, cutoff the revolving ring and hammer an qqold socket over the top.
Is the wheel lock key hanging from under one of the seats. In the past the Wheel Lock kits came with a zip tie that had a special end that would hold the key.
Another place to look would be in with the jack handle.
mikeru
Super Moderator
Moderator Supporting Member
2020 Limited
Hemi 5.7L non-Etorque
Most of the tire shops in my area have keys for just about every wheel lock you might have. I know my local Les Schwab tire center has saved me grief over not having wheel lock keys.
Rlaf75
East Hartford CT
2021 Bighorn
If they are dealer or factory installed locks most if not all dealers should have a "master" wheel lock key for purposes just like yours. They may require you to provide identification in order for them to remove it so they can make sure you didnt steal the vehicle. The shop I used to work at had a master key just in case the customer lost the key
Lee955i
Lakeland, Fl.
Glad I came across this. Just noticed my new truck had locks on it (even though it's not on the monroney) and searched high and low for a key, including under the seat, with none to be found. Guess a dealer trip is in order...
