What is the benefit of downsizing from 20" wheels to 17" or 18" other than looks. Wanting to get rid of factory SR-A's. Thinking about staying same height tires but wider. Not wanting to give up much in mpg.
Thanks
Thanks
17's are the smallest wheel diameter you can goI also am looking to go away from the factory 20's I am looking to get the smallest wheel diameter I can put on my 2017 Express Crew I am a big fan of the smaller wheel more tire combination but want to stay with stock tire height a slightly wider tire would be fine. I am wondering if anyone has specific wheel sizes and widths and offsets that would keep things relatively stock configuration. thanks for any information
I changed from 20" to 17" Rebel wheels with 285/70-17 E Falken A/T3W tires.
Here are the wheel specs and a pic.
I am getting ready to do the same thing going from stock 20's to 17" Rebel wheels and probably the same tire and size. Did you have any issues with rubbing or anything. I don't plan on installing wheel spacers or a lift or anything else. Anything I need to watch out for? Thanks
Rebel - 17x8.0 Wheel - Offset +18.05 mm - Back Space 5.50”, 29 lbs
Big Horn - 20x8.0 Wheel - Offset +19.5 mm - Back Space 5.25”
Laramie - 20x9.0 Wheel - Offset +19.5 mm - Back Space 5.75"
All:
Lug Pattern = 5 x 5.5” (139.7mm)
Studs = 9/16”, Thread M14x1.5
Hub Bore = 3.06”/3.075” (77.8mm/78.1mm)
TPMS Sensors = 68249197AA
