wheel tire combo -- what do you think??? LT285-70R17 w.
SouthShoreRAM
what do you guys thing of this combo? and do i need more offset for the 285's on stock '14 1500 suspension?? also my paint is the granite metallic (dark grey?)
khumo road venture tires:
LT285/70R17
Sidewall Style: Blackwall
Load Range: E
Serv. Desc: 121/118R
kMC rims
17x9
Finish: Black Painted
18mm offest
Jerry1984
Meridian, Idaho
It will work fine. I had 33x12.5 with 17x9 -12 offset at stock height and didn't rub. Those tires are basically same height as stock 20 inch setup.
I'd recommend 0 offset as they look better in my opinion. If you prefer the tucked look the +18 will work.
S
SouthShoreRAM
thanks, i am still looking at a few rim options, and may consider closer to 0 offset.
problem is...dont have fender flares yet, and not sure i want them.
S
SouthShoreRAM
sorry 1 more question -- are there any other site you guys recommend other than tirerack for wheel/tire combos??
i am on the fence over going to 18x9 to keep the specs as close to stock overall ride height and the 18' options on tirerack arent doing it for me.
CDNUSER
