Where do i put the amp?
CumminsPastYa
5.9 Cummins
I am getting a sub setup in my 2006 dodge ram 2500, and the box is going underneath the back seat with a fox box. I have everything figured out, i just dont know where to put the amp at. Any ideas? What have you guys done if you have an amp?
redram2007
Colorado Springs (Ft Carson)
Some have put them on the backside of the rear seat, but that takes a little work. You may also consider putting it under one of the front seats.
ZakkBaker
FTW, TX
5.7L HEMI
Yeah I've heard of it under the driver or passenger seats.
Also behind the bench mounted to the wall like red ram said, there is a thread about it on here somewhere.
WhiteExpress
Midland, TX
I would mount it on the rear cab wall like Zakk linked you too. It's a safe place.
Just leave the seat down for a couple days till you get your settings dialed in.
Once I've tuned my system, I don't recall ever touching the amp again.
ram-head
Arkansas
I put the one for my doors under my driver seat. The one for my subs was small enough to fit between the box and the rear cab wall.
King nothing
Central IL
Cummins
My amps are under my front seats. had to remove the factory jack stuff under the passenger seat
