White gunk in engine.
MarkV
Ontario, Canada
4.7 Magnum V8 NOW with Moose Power
With a 4.7 the pcv valve goes into where you fill the engine with oil and there is always white gunk - oil and condensation. Is there any ways around this? Or aftermarket fixes? I know it is not coolant.
89gtcs
If you make a lot of short trips, the engine doesn't get hot enough to burn off condensation. Try a longer trip and make the engine work a little, then check.
MarkV
MarkV
Ontario, Canada
The previous owner only drove it 5 minutes 2 times a day....but when i drive it i have it on for at least 30 minutes plus. and there have been quite a few long drives in there to. And it runs at 95 to 98C
hemihustlin
Lower Southwest Quebec
Try cleaning it out real good and see if it comes back. Condensation is normal
In the winter. I wipe out the little drops of water underneath my oil cap every time i check the oil so the white slime never even has a chance to form!
joshhhh
