How to Maximize Engine Life
HEMIMANN
Minneapolis, MN
2017 2500 Laramie Crew Cab
6.4L HEMI
This guy's data says engine wear is reduced the greatest amount by fewest cold engine starts. i.e. - most engine wear is caused during cold engine starts.
Three ways to mitigate - (1) run engines long miles between shut downs, (2) minimize idling, (3) use oil and coolant heaters an hour before starting.
Of course, other things may fail first, the sheet metal might rust off, the seats might disintegrate, etc. so you'd want a new vehicle anyway. But the way new vehicle design is failing now, many of us don't want a new vehicle.
Burla
Army
2010 Hemi Reg Cab 4x4
Lot lizards know about heated dipsticks...
They are a beneficial species, some might say keystone species.
A keystone species is an organism—often a predator, ecosystem engineer, or plant—that holds an ecosystem together, exerting a disproportionately large impact on its environment relative to its abundance. If removed, the ecosystem changes drastically or collapses.
Speaking from a guy who had two overnight runs per week for a decade, awe the memories, lol.
YetAnotherUser
