Will a leveling kit effect overall height of truck
v8only
I have an 05 quad cab 4x4.....i use it for work often which includes offroading to cell sites and city duty too...i go in a lot of parking structures and therefore don't want my over all height changed as its already too high for some parking structures.....
My question is....i really need more front ground clearance that a leveling kit would provide...if i do this will it raise the over all height...or will it just bring the front of the roof up to the height that the back of the roof Is already at..not sure if anyone had examined this this closely
Sent from my SPH-D710 using Tapatalk 2
Stangshcky12
Oshkosh, WI
5.9 Cummins
It will bring the front of the roof up more but the rear will come up some as well
quietpeen
2021 TRX
Hellcat
Yes it will be a little taller
To save some money since you. Have an 05 you don't need to buy anything. Just crank your torsion bars
V
v8only
Thanks guys I have heard mixed results about just cranking up the stock stuff but guess its worth a try...just aligned the thing too damnit
NWRQC
The alternative is to buy a lift kit or a body lift which will raise the front and back.
hawk8945
It will raise it up some but you will definitely get enough clearance all the way around that you will need. My 07 still fits in my garage at home without any troubles so should be ok.
dakota18
