will i get voided
dannyboy
ok i just bought a new 2012 ram express and the dealer told me i can only put mopar aftermarket parts on my truck our the warrenty will be voided i dont want mopar cai or exhust would rather have something like magnaflow exhust so is this true
4x4Hemi
Edmonton, Alberta
nope not true at all. just refer him to a magnuson moss act i believe it is. He would have to prove that it was the exhaust fault that made something on your truck fail. but if you put a 12" lift and something goes wrong, then it might be voided haha
D
dannyboy
ok was woundering becouse it sounded like some bs
4x4Hemi
Edmonton, Alberta
It sure is, i just bought my truck a month ago and put on a new exhaust as well. nothing to worry about with exhaust and CAI.
MADDOG
Living in a Firepit
The Magnuson-Moss Act outlines the rights of buyers and sellers with respects to warranty claims.
Basically, if you modify your vehicle and that modification causes damage to other OEM parts, those parts won't be covered. And, of course, neither is the aftermarket part.
However, the seller cannot blanket void your warranty simply because you modified your vehicle unless the first case above is the cause and result.
Let's say you install a supercharger on your stock engine and the engine fails. No warranty for you.
On the other hand, let's say you installed an aftermarket cold air intake and your audio head unit fails. The mod you did has no affect on the failed part and that part should be covered under the warranty.
Normally, the burden of proof that an item is not covered under warranty rests with the seller. Most cases are settled in arbitration.
So what your dealer told you is what they are trained to tell you but it's not necessarily the whole story.
quietpeen
2021 TRX
Hellcat
yea you will be fine. I have a magnaflow on my truck and love it
MidnightRambler
North Carolina
HEMI 5.7
Good to know. I was worried about this. I want to trade head units/swap exhaust/install a TB/CAI. Time to get to work lol
