Will Single cab suspension fit QC
justin443
Houston, TX
2010 RAM 1500 Sport 2wd
as stated. will single cab suspension fit my QC? its coming off a single cab R/T and im going to put it on my QC Sport. will it work?
quietpeen
2021 TRX
Hellcat
im not saying yes, just saying i would think it would be the same
justin443
justin443
Houston, TX
i guess we will find out for sure! thanks
Trupiano
Registered User
6.7L CTD
Are you sure? I know the quad and crew cab springs are different. I don't see how the rear springs would be the same. The quad cab weighs alot more, then the SC does. They almost can't be the same can they? They might look the same, but the spring rates will be different to handle the weight.
justin443
justin443
Houston, TX
well, it came off an R/T, i am going to do the install this weekend hopefully if the parts get here. il let you all know and post before and after pictures, im going from a belltech 2/4 drop to the stock height then to the readylift SST 2.25/1.5" lift
justin443
justin443
Houston, TX
my brother in law is a mechanic he ran the part number in his system and the part number is the same for all 2WD
southalum
