Will the tow mirrors work?
PCT
2019 2500 6.4
Northern California
Afternoon forums, i have the stock SLT ram mirrors.They are power, heated, and has the thermometer in it. I would like to swap them out with some tow mirrors because of my toy hauler. If i were to buy some mirrors with that, aswell as the puddle light and blinker, will they work as a plug and play? Or will that have to be modified to work?
If i have to modify it, if its annoying i wont do it so just want to know if the mirror will be plug and play, or just get the same mirror just towing?
Little Red
NY, USA
99% sure they're bolt on, since they were a factory option. I think you need to have the dealer change (reflash? not 100% sure) your computer so it knows that you have different mirrors.
D A
San Antonio TX
What year SLT do you have? I've got the 2013 Laramie with tow mirrors but I want the regular oem power fold mirrors with all the bells. A local dealer here told me he didn't think the swap could be done but I'm not sure about that yet. It would be cool if it were a simple plug and play swap.
Don
PCT
PCT
2019 2500 6.4
Northern California
i have a 2013 ram 1500 SLT, with the stock mirrors Power heated thermostat. on my 2004, it was plug and play, but then again it was just the power and heater
saintsreturn
Home in St. Pete, FL
2015 Longhorn
EcoDiesel
When I went to do this on my Lone Star, I was told I would need to flash an update for the truck. Just an FYI
brandonjansen
Abbotsford, BC, Canada
2012 Ram 3500 Laramie Limited
No need for a flash for the mirrors. However you will need tow mirrors from a '13+ because of the temp sensor being in them. Turn signals aren't plug and play (at least they weren't on 09-12's) but you can wire them in yourself.
Nicmabry01
For the puddle lights you'll need to have flashed I believe
cgeorgemo
Joplin, MO
3.6 Pentastar
Flash sales codes LEB and LEC to turn on turn signals and puddle lights. I recommend getting the reinforcing brackets so that they won't vibrate badly at highway speeds.
PCT
PCT
2019 2500 6.4
Northern California
haha so dont need to flash, so do i need to wire them for turn signal and puddles, or bring to chrysler and have them flash it?
PCT
PCT
2019 2500 6.4
Northern California
sorry that doesnt make sence haha, so i dont need to flash to plug them in... what i ment
Nicmabry01
They are plug in play but I believe in order for the puddles and signals to work it needs yo be flashed
cgeorgemo
Joplin, MO
3.6 Pentastar
is that like an hours labor? how much does it usually cost?
That will vary from one dealership to another. My local one charges an hours labor for a flash while the dealer one town over charges 1/2 hour.
So it's $100 or $45 for me.
PCT
PCT
2019 2500 6.4
Northern California
awesome thanks. Where would be a good place to get them for as cheap as possible? ebay?
cgeorgemo
Joplin, MO
3.6 Pentastar
BLKMAGIC
I did this swap, there are 3 codes that need to be flashed by a dealer to make them function 100%. If you do a search for working tow mirror upgrade, there is a long thread with the correct codes.
One is for turn signals, one is for puddle lights, and the third is the generic tow mirror code, which will allow the power operation to work properly when they are up.
They MUST be 13+ mirrors with the temp sensor, or you will throw a CEL and the truck will run crappy.
*EDIT* Here is the link to the thread http://www.ramforum.com/f41/working_tow_mirror_upgrade-51611/
Lemniscate_Mike
