Windshield drain holes?
goodtodoo
1996 indy pace truck
So I have the windshield plastic cowl off the truck. Its full of crap underneath. Are there any drain holes I should clear out? Thanks.
G
goodtodoo
Bump. There must be a place for water to go.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
It drains from the sides, it's formed into a crown like the highways to allow water runoff.
G
goodtodoo
So is there anything I should clean out? before I put cowl back on. I vacuumed everything out that I can see. Thanks.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
As long as it's clean under you should be good, you can look before you put it back and see up by the windshield where the water goes. If you look between the rear top of the fender and either side of the firewall you will that it's pretty much strait down.
G
goodtodoo
Thank you. I just hate doing things twice.
