Winter grill cover?
05ram4x4
2002 Ram 2500 4x4 Quad cab
5.9 Magnum
I had the engine light come on yesterday and it was saying the engine was basically too cold. I also now that it takes a little while for it to warm up in the morning...especially lately with 6° weather.
I was wondering if I should put a grill cover on. Or a piece of cardboard in front of the radiator. I now diesel trucks tp ot...but what about me with my hemi? i guess its worth a shot but could it hurt anything?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
May have a stuck open thermostat. Never had any issues and it gets real cold here. All I do and it has to be really cold is put a piece of cardboard box in front of the rad and zip tie it on as there are holes along the top of the rad lip........Perfect.
05ram4x4
05ram4x4
5.9 Magnum
I thought about the thermostat. There isn't any way to check test without taking ot out is there...
NITROUSCHRIS
consumer of excess fossil fuels
Wisconsin
blown 6.1
I also use the cardboard trick as it helps get heat in the cab faster on my short drive to work. Also if the thermostat is stuck open the system won't pressurize and the upper hose will not get hard. Something to check.
05ram4x4
05ram4x4
5.9 Magnum
Thanks! Ill have to check that.
A/C0197
My dad has a '96 V10 and he has put cardboard behind the grill for the last 10 years or so (about 2/3 of the entire area). Only during the winter due to being in Florida. It makes a big difference.
blue dodge
4.7 magnum
i live in Alberta and it -30 degrees Celsius and the cab take like 20 mins to warm up. a grille cover is a need.
craigsez
Novascotia,Canada
I sometimes use a plastic house floor matt(somethin you put yer boots on in the porch and a cpl bungie cords when i do alot of highway driven to my parents or son/brothers house..
chedched
Madison, WI.
2019 Power Wagon
Um, the truck is designed to work one way and that is without the cardboard/winterfront. If you are doing this you could potentially cause some issues. If the truck isn't warming up, fix it. Bandaids cover the problem but don't fix them...
