Help please
Ian_Olivas
San Antonio,Tx
4.7L Magnum
2019 ram 1500 rebel 4x4.
Dash has been lately saying shift to park while I am in drive. Today while coming to a stop. I felt sputtering then when hitting the gas pedal the truck was not accelerating. Like if the transmission was not delivering power. When coming to a full stop the engine shut off. Upon restarting the transmission still felt like it was not engaging then engine died again. Eventually got it going then while at 80mph i felt the transmission disengage again and slow down, then coming at a stop the engine cut off again
Ian_Olivas
Ian_Olivas
San Antonio,Tx
4.7L Magnum
And / or dirty or corroded battery terminal connectors and posts.
My money is on a weak battery. Bogus lights on the dash accompanied by in and out of limp mode and engine dying. Just what mind did last year. Let us know what you find.
I just bought a new battery about 2 months ago. Terminals look good. Ill check to see if maybe theres a loose ground somewhere tho
Ian_Olivas
Ian_Olivas
San Antonio,Tx
4.7L Magnum
Any codes? This sounds like a dealer problem.
No codes had it checked and its not spitting out any. My research is pointing towards a Trans range sensor but I guess I'll pay for a diag furst to be sure
Top Mule
Las Vegas Nevada
6.7 Cummings Diesel
If you replaced your battery, did you check the charging system? My dodge had a perfectly good battery but the charging system was dead. It shut down the vehicle instantly. In my case, I had to tow mine to a dealership.
Ian_Olivas
Ian_Olivas
San Antonio,Tx
4.7L Magnum
No I did not but I will now it hasn't happened since friday and has been driving fine since. It just happened to do it while i was driving 5 hours to another city
lchicago
