Wiring in backup camera?
hemi1300
Columbus, Ohio
Gonna be installing the cam on my kenwood soon. I know the composite cable obviously plugs into the back of the unit, black wire to chassis, does the red just tap into the tail light wire for the reverse lights? My only confusion-there is a purple/white wire hanging right out the back of my kenwood ddx418 labeled reverse, and also the same color wire on the harness, but I don't have them spliced together yet. From my understanding, no wire taps should need done behind the head unit for it to switch on the cam when reverse is applied, just tap into it at the tail light, correct?
zack
pa
2004.5 packing the smarty
5.9 cummins ho
Bump some one will chime in
hemi1300
hemi1300
Columbus, Ohio
Hopefully lol. Might pick up a cam this weekend and just want to make sure i get it right
Sent from my DROIDX using Tapatalk
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Sorry no help used lock pick to add mine to RER radio
$miley
LB3711
Trumbull, CT
3.6L V6
you need the manual and it should say there.
HemiBabe
DFW
I wish I could help you, lol. The manual should say or if you don't have it, usually the manufacture's website will have a manual you can download
ramfanatic
Banned
the purple and white wire coming out of the radio needs tapped into the reverse pos wire so when you hit reverse it triggers the radio to show the camera
