Won't run when temp is below 45 degree
David W Robinson
I have a 2010 ram 1500 5.7. When the temp is in the teens and 20's the truck will not start, the check engine light comes on with a P0300 code, misfire. I take the neg cable off the battery to reset the pcm, then hook the cable back up and it starts up fine, no codes. It runs great like nothing was wrong. And starts everytime after that. It only happens when it freezing.
Anyone know whats going on. Thank you
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
When was the last time that you had the battery load tested
Batteries really strain in cold weather
David W Robinson
David W Robinson
I bought a new battery about 3 or 4 mounts ago. I will put a charger on it to see if that works.
4xdad
Edmonton Alberta
2015 powerwagon
He’s right you’re battery doesn’t work as well in the cold the computer doesn’t like low voltage the colder it is the the worse it gets connections need to be checked out to
David W Robinson
David W Robinson
Ok, I will have it load tested. Thank ya'll very much for the response.
4xdad
Edmonton Alberta
2015 powerwagon
Was your truck sitting from a long time their is always a parasitic draw
David W Robinson
David W Robinson
Just when sitting overnight. When I try to start it, the starter keeps turning after I let off the key
Dean2
Near Edmonton
That really isn't very cold weather but yes batteries are less effective at 20 than at 70. Any new battery, unless it was defective from the start, should easily start a truck at 20F.
They start here at a lot colder temps than you are seeing.
I would get the Battery load tested to be sure, but you may very well have ground issues. If the battery tests out good I would clean up all the ground connections I could locate.
