Would cranking be to much for my axles
livefast304
Hey everybody, jw if I would really be fine leveling my 04 qc 4x4 about a inch and a half without killing my axles..I have new tires sitting in my garage as we speak but I was gonna level the truck before throwing them on then go ahead and align the front end after I crank the bar to level it?
NWRQC
You should be fine if you keep it at or below about 2". If you want more than that I would recommend a lift kit.
Yes anything over 2" you run the risk of having the CV boots hitting the lower control arm when the suspension droops down. I figured that out the hard way and went through two sets of cv axles until I figured it out. I set my suspension up so the front is only about an inch lower in the front.
Kamikowski
