Wrecked 2010 ram
Jackhowell
Juneau alaska
I bought a 2010 ram 1500 a little while ago i cant figure out whats wrong with it, it was wrecked on the front drivers side the airbags deployed there is no power to the dash or ignition fuses all check out headlights work seats power works but thats about it
jawzs2
Air Force
South Jersey
Did you look through the factory service manual I linked to in one of your other threads? It has diagnostic procedures, wiring diagrams and troubleshooting steps. Only way you're going to track it down. There's no way to guess what it is if it got hit, it's going to take perseverance to fix it, no quick fix or magic bullet.
jws123
nj
Just a wild guess are you sure you have the correct key for the truck? take the internal key out of the fob see if it fits the door. If it was hit on the drivers side I assume the tipm probably got damaged how bad was it hit?
KAKA
