WTB: Complete 5.7 non mds set up
Status
Not open for further replies.
The Assassin
B-more careful, Murderland
Looking to do a swap in my truck. Need the motor (duh) and harness, and any other associated, and necessary wiring. I'd love to do a 6.1, but that would be too much to do with the tranny and gears.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Whats the amount of money your looking to spend and are you looking for performance?
quietpeen
2021 TRX
Hellcat
he has the 4.7
The Assassin
The Assassin
Well, I have been looking on ebay at motors, they are running between 3-5 grand, so I guess in that range. Then I also want to do headers, will need a new CAI, might as well do a cam too..plugs and wires, then install it. Eventually might look into a STS rear mount turbo.
umm why not get a superchips and disable it...
They are both correct, I have a 4.7...I am going to be doing a larger lift, and tires, so i need more performance out of the engine. So, might as well just start there!
he has the 4.7
I think he has a 4.7
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Call Stu at Inertia Motorsports at 1-512-964-7724 and tell him Kenneth sent ya. He can set you up with something if thats the range you want to be in. If he cant get close enough he might have a hook up for you.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
screw it, drop a CTD in it! :D
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
its only money.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
^True... thought has crossed my mind now the I need to put a piston in mine. Book is calling for a retarded amount if time to swap em. Assassin I would look into fordged pistons and rods if your planning on doing foreced induction or spray to be on the safe side.
The Assassin
The Assassin
Should be ok running a rear mount...if it was a supercharger, or spray then I could see it.
glass3222
Central PA
What about a supercharger, cam, and headers for the 4.7?
That would make good power and probably be easier to do that a hemi swap.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Status
ChloeBrooks
