~~> Yo Nadz STOMPER Build Thread...
Fort Worth, TX
TBD EcoDiesel
The pics posted with the new halos sparks a question...does the truck still fit in the garage in the background with that setup? Also do you have any rubbing? I'm on the fence with what setup to go with that will still fit in the garage!
Y
Yo Nadz
St. Louis, MO
Hemi 5.7 Sport Crew Cab 4x4
It just barely fits. 7 foot door and I've got about a quarter inch of clearance. Gotta take it slow and remember not to pull in or out if there's snow on the drive.
Rubs the gap guards at full lock in the front. I could cut them a little, but it doesn't bother me enough.
RamVillian14
Macon, Ga
Just bumping my question incase you missed it.
I didn't think this would effect that feature, but now I'm curious as well?
My truck is very similar to his and I have been enjoying this thread a lot. Thanks for all the info.
tipnitty
Oklahoma
Truck looks sick man. I thought I had seen your pictures before, and sure enough I have. Good ole STLSR. I'm from Lake St.Louis and recently moved away before I bought my truck. Keep up the good work sir.
Y
Yo Nadz
St. Louis, MO
Sorry for the late reply. The garage has a 7' door and it fits! but just barely. The shark fin antenna has about a quarter inch clearance. Hope that helps!!!
quinton579
are those stock tail lights? cause if they are ive been looking for ways to tint my 2013 tail lights as well but havent come across a foolproof way yet
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
Sport 13/14 tail lights are slightly tinted. So to answer your question, they are stock :D
quinton579
my 2013 lights definetly arent that dark. i wish!!!
Y
Yo Nadz
St. Louis, MO
I tinted them with NIGHTSHADES" spray tint. It is really easy to do yourself. Just remove the tail lights, scuff the lenses with some fine grit sandpaper, clean them with alcohol and lint free towels, and you're ready to go.
I taped off the lights and sprayed about 4 VERY LIGHT coats of the tint. Take your time and let them dry for about 10 minutes between coats. The spray tint covers well, and gets really dark if you put on too many coats.
You can stop there, or if you want a gloss finish wet sand the lenses and shoot them with a couple coats of clear.
SuperTrooper
Douglas, GA
Just out of curiousity, Can a Ranch Hand or Bull Bar still be installed with a body lift like you used?
glenval
Did you run one cutout at 3in pipe, or two cutouts at each back of cat?
Reticle918
