View Single Post
Old 07-07-2015, 02:53 PM   #10 (permalink)
DodgeDrew71's Avatar
DodgeDrew71
Ram Year: 2001
Engine: 3.9
Default
Originally Posted by tommyboi87 View Post
So opening the holes helped that much huh? Think you can post a pic of how much you open them all together?
Sent from my SAMSUNG-SM-G925A using Tapatalk
Sure, it'll probably be a couple weeks before I get back to it.
But I can tell you I lengthened the slots more than a 1/8" but less than 1/4" (toward to tire) I didn't take a hard measurement with calipers prior, wish I had now, but I didn't want to over do it, so will take a crack at it again and head back to firestone.
I'm going to lengthen it about 1/8" more and see if that will get me to zero camber. But a little negative isn't bad, but -2.0 was too much for a street use truck. (would like to get it between -0.25 to 0.00)
__________________
-Drew
2001 Ram 1500, 2WD, Std cab, 3.9
2/4 drop from Suspension Specialists
Volant CAI, Magnaflow Exhaust (cat back)
DodgeDrew71 is offline   Reply With Quote
