Alignment "issue"
Discussion in 'Lowered' started by DodgeDrew71, Jun 2, 2015.
  1. tommyboi87
    tommyboi87 Senior Member
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    So about 3/16 in so far? Mine was about as bad as yours. Might have a little weekend project now.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
  2. DodgeDrew71
    DodgeDrew71 Member
    75
    43
    Apr 26, 2015
    Ram Year:
    2001
    Engine:
    3.9
    Yeah I'd say 3/16" is about right.
    I actually just took a permanent marker and made equal markings of where to remove material and went at it. BTW-- I used a step bit to do it and it made it easier than with a drill bit.
    SureBilt/3 pcs. step drill set 82032 at AutoZone.com\\
    But I bet if you had the right grinding stone a dermal may work.
  3. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    Ok, so this is probably the dumbest question I've asked to date. What holes did you lengthen? Took my control arms off, and couldn't figure out what to expand.
  4. HeavyD
    HeavyD Senior Member
    1,128
    237
    Feb 21, 2015
    Medicine Hat, Alberta - Canada
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    The slots where your upper arm on the frame.
  5. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    The slots on the frame?
  6. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    Yes, they have long slots but not long enough if you cut the springs too much.
  7. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    That's what I thought. I just didn't want to start cutting blind like a b dumb ass lol
  8. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    how much did you lower the front?
  9. tommyboi87
    861
    205
    May 28, 2014
    houma louisiana
    Ram Year:
    1999
    Engine:
    5.2 Magnum
    4"
  10. HeavyD
    1,128
    237
    Feb 21, 2015
    Ram Year:
    Engine:
    4.7 SOHC 5 SP Auto
    is that all springs or ?
    did you install a drop knuckle?
    I did 2 3/4" springs & I had to make camber plates due to not enough length in slots & it also helped the a-arm angle.
Share This Page
