Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > General Discussions
General Discussions
Transmission Only Engages Under Heavy Acceleration
This is a discussion on Transmission Only Engages Under Heavy Acceleration within the General Discussions forums, part of the 1st Gen : 1981 - 1993 category!
Hey guys. I have an 84 d150 with 727 trans and a 5.7L Hemi that I swapped in last fall. ...
Reply
Old 05-21-2017, 04:30 PM   #1 (permalink)
Ram Year: 1984
Engine: 5.7L Hemi
Default Transmission Only Engages Under Heavy Acceleration
Hey guys. I have an 84 d150 with 727 trans and a 5.7L Hemi that I swapped in last fall. When the truck is cold and I have it in drive, the engine will rev up and almost have a "diesel" type sound, so I back off the gas pedal then step on it again harder and I can feel the flywheel (?) engage this time. It will not engage at a few accelerations but eventually warms up and doesn't give me a problem anymore. It has enough trans fluid and doesn't have a leak. Also, this might be related, but I can't spin my tires from a dead stop. With my old gutless 318 I could spin, but not with my 370hp fuel injected hemi. This seems strange to me. The rest of all three gears have plenty of power though. Does it sound like maybe the starter gear is engaging when it shouldn't be? This could explain the "diesel" engine sound that happens only when I have this problem?
Sponsored Ad
Register to remove this ad.
Yoox_II is offline   Reply With Quote
Old 05-22-2017, 09:19 AM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
have you checked the adjustment on the kickdown linkage? if it is not adjusted properly it can cause the transmission to shift too soon even under full throttle and cause the engine to almost bog enough that spinning tires is impossible. i know on a rainy day i can spin through all 3 gears in my 81 but it is still usually in the 2000-4000rpm range the whole time.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cummins diesel + Aisin transmission heavy hauling MPG Valhakar Towing & Hauling 15 01-01-2016 01:31 PM
What is "Heavy Duty Transmission Cooling" Pitch1 Tech Info 3 09-07-2015 05:32 PM
4x4 engages automatically cdharvey89 Engine & Performance 0 07-27-2015 04:20 PM
2015 2500 heavy duty 6.7 transmission honeybuubuu Engine & Performance 4 04-01-2015 06:18 PM
03 dodge ram 5.9 gasser blows black smoke under heavy acceleration? mcCraw Engine & Performance 12 08-20-2014 01:59 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
