Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Engine & Performance
Freeze plug looks bad
This is a discussion on Freeze plug looks bad within the Engine & Performance forums, part of the 1st Gen : 1981 - 1993 category!
Any one replace freeze plugs on a 318 before? Does not look all that bad, just gotta remove the starter. ...
Like Tree1Likes
  • 1 Post By duncman
Sponsored By: Moe's Performance
Reply
Old 08-03-2016, 02:17 PM   #1 (permalink)
Ram Year: 1986
Engine: 318 V8
Default Freeze plug looks bad
Any one replace freeze plugs on a 318 before? Does not look all that bad, just gotta remove the starter. I have never done freeze plugs before but they do not look all that complicated.
Sponsored Ad
Register to remove this ad.
duncman is offline   Reply With Quote
Old 08-03-2016, 03:39 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
it will most likely be a bit harder than you think but not too bad. just get some good quality freeze plugs and you should be good. you might have to fight to get the starter out of the way but i think it is possible.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 08-03-2016, 05:58 PM   #3 (permalink)
Ram Year: 1996 RAM 2500
Engine: 5.9 Gas
Default
I haven't done mine yet, but I know that one a 289 that I'm helping with we had to drain the coolant and pull the coolant plugs from the back of the block. After that it was removal of the starter and pop them out. Clean the seat really well and seat them back in.
Sent from my E6653 using Tapatalk
Kpearson is offline   Reply With Quote
Old 08-03-2016, 08:50 PM   #4 (permalink)
Ram Year: 2001 ram 3500
Engine: V10
Default
that is a pretty common issue with older LA engines, especially if the coolant mix has not been maintained faithfully, The way the coolant circulates, the left side freeze plugs rot first. Then the back of the block plugs go next. When you drain the coolant, replace all the left plugs at the same time. Use brass plugs if you only want to do it once and you plan on keeping the truck for awhile. While the plugs are out use compressed air and a garden hose nozzle to wash out all the rust and sand which has piled up in the water jackets and against the plugs, causing the plugs to rot. Use that dark brown Form a Gasket (#2?) goo to coat the sides of the plug, prior to insertion .
Rustycowl69 is offline   Reply With Quote
Old 08-09-2016, 11:21 PM   #5 (permalink)
Ram Year: 1986
Engine: 318 V8
Default
Thanks for all the advice. I was able to swap the freeze plug out with out that much trouble, just had to drop the starter and I had all the room in the world.
The coolent system was nasty, looked like mud had gotten in there, I was able to flush the block and the radiator real good to get all of the gunk out. I buttoned everything up and drove it around the block with no leaks. I park it and start putting tools away and I hear water dripping, I look down and there is a steady stream coolent leaking from under the truck. After some investigation I find that it's coming from the weep hole on the water pump, so now I get to pull that sucker off tomorrow. Weeeee
Old 08-10-2016, 12:21 AM   #6 (permalink)
Engine: V10
Default
HAHAHA, I forgot to mention the corollary to Murphys Law. Shortly after draining, flushing, and refilling with fresh anti freeze, another leak will appear, and you will lose most if not all your new coolant.
Old 08-11-2016, 06:50 PM   #7 (permalink)
Ram Year: 1986
Engine: 318 V8
Default
Water pump is in and no leaks so far! Thanks for all yalls help on this.
dev199505 likes this.
Old 03-14-2017, 04:33 PM   #8 (permalink)
Ram Year: 1995
Engine: 5.2
Default
Does anyone know how much coolant ill lose replacing the 4 accesible ones on the 5.2 engine? I've been catching most of what's leaking out and I'm at about 2 gallons
ajmecum5.21500 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2014 anti freeze part # jag1886 General Discussions 3 08-17-2015 07:43 PM
Gas line freeze problem? fostagnasty General Discussion 2 01-28-2013 03:17 PM
anti freeze smell Reaper26 Engine & Performance 4 11-15-2012 10:27 AM
Plug in: gas line anti freeze ziggles General Discussions 9 10-31-2012 01:02 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
