Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
clunk sound going into gear
This is a discussion on clunk sound going into gear within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
I have a 88 D100 with a 318, not sure what trans. I just bought this truck last week for ...
Reply
Old 05-11-2013, 02:48 AM   #1 (permalink)
Ram Year: 1988
Engine: 318
Default clunk sound going into gear
I just bought this truck last week for $650. Has 149xxx miles and honestly drives really good. I have been doing minor things to it the last week. Changed spark plug wires, spark plugs, battery, oil/filter, air filter and aftermarket temp gauge. Trans fluid is next weekend.
Ok so my problem is when i go from park to drive or reverse there’s a loud clunk noise and sometimes a small jump. Also a vibration sometimes while driving. I’m thinking it’s the u-joints.? I already bought new u-joints so as soon as i get time I’m changing them.
Can it be something else? Any help would be great!
THANKS
Sponsored Ad
Register to remove this ad.
Rookiemoto is offline   Reply With Quote
Old 05-12-2013, 11:05 PM   #2 (permalink)
Ram Year: 1988
Engine: 318
Default
Update...
Changed my u-joints and there’s no difference.
Any other suggestions??
Old 05-12-2013, 11:16 PM   #3 (permalink)
BAILEY1's Avatar
Ram Year: 2014 Jeep Wrangler Willys Edition
Engine: 3.6 Pentastar
Default
If it was not the u-joints, then I would definitely check to see how much slack you have in the ring and pinion. Is it making a low "drone" noise when you going down the road?
__________________
Black Truck Club #70 - Louisiana RAM Owners Club #1
BAILEY1 is offline   Reply With Quote
Old 05-13-2013, 12:00 AM   #4 (permalink)
moparman's Avatar
Ram Year: 2012 Express CC
Engine: 5.7
Default Re: clunk sound going into gear
If it sounds like an airplane going down the road then youre in trouble. Sounds like a bad pinion bearing if you still have vibrations with new u joints. Crawl under it and try to move the driveshaft up and down at the rear. If theres no play then its good, if there is play then thats the problem. Same thing happened to mine, pinion bearings took a dump.
Sent from my Galaxy S3 using Tapatalk 2
moparman is offline   Reply With Quote
Old 05-13-2013, 02:31 PM   #5 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
that clunk noise is normal with most older dodge transmission. if you start your truck in neutral i am pretty sure you should not have that noise. have you checked the rear differential fluid level?
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 09-13-2013, 12:00 PM   #6 (permalink)
Deblackmon3's Avatar
Ram Year: 1990
Engine: LA 318
Default
Kinda jumping in on here late, but I also have clunking from my transmission, mainly going from any gear to reverse. I know there's the light clunk from just shifting gears, but whenever I go into reverse, there's a loud scraping noise, and I mean LOUD. Like, I get looked at from across a parking lot because it catches their attention.
If anyone can tell me where to find the fuse box too, that'd be great, cause my reverse lights don't work.
Deblackmon3 is offline   Reply With Quote
Old 09-13-2013, 12:04 PM   #7 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you may want to check the differential fluid level and universal joints if it makes that much of a clunk when going from any gear into reverse.
i think this should be the same for 90 but not sure. if fuse is fine then you may want to start another thread on the issue so that we don't thread jack this thread too much.
__________________
Old 09-13-2013, 12:14 PM   #8 (permalink)
Ram Year: 1990
Engine: LA 318
Default
I'm thinking it's the differential fluid, only because it sometimes clunks, but not all the time and with varying loudness. If the car is just starting up, it's loud, but if the engine is warm (which I assume the fluid is warm and lubricated the diff) it is just as quiet as any other gear change.
Old 09-13-2013, 12:40 PM   #9 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
did you read my post about starting the truck in neutral? these trucks do not pump fluid in park so if you start the truck in neutral it should not make that noise. that big bang is fluid starting to pump and stuff starting to engage.
__________________
Old 09-13-2013, 01:12 PM   #10 (permalink)
Ram Year: 1990
Engine: LA 318
Default
OHHHHHHHHHH! That makes alot of sense. I forgot that you can start in neutral. But if it doesn't start pumping fluid in park, why wouldn't it make a clunk when switching to any other gear? Is it just the way the reverse gear is different than the rest or do I seriously just need to read up on my transmission stuff?
Reply
Tags
clunk sound in rear, noise when shifting
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
susupension noise / clunk + wheel bearing noise? sdamike General Discussions 7 02-26-2013 04:20 PM
Front end clunk tmac Lifted 10 07-01-2012 12:50 PM
Rear diff / tranny clunk Rotzilla Engine & Performance 16 05-27-2012 02:45 AM
More sound. dodge15004x45.9 Interior 1 12-17-2011 09:28 AM
Left turn clunk treefg General Discussions 13 09-18-2011 05:00 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
