Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Tech Info
Tech Info
Sending unit removal
This is a discussion on Sending unit removal within the Tech Info forums, part of the 1st Gen : 1981 - 1993 category!
I recently acquired an 88 power ram with 38k miles one owner truck. It's sat for nearly 20 years and ...
Reply
Old 06-02-2015, 05:24 PM   #1 (permalink)
Ram Year: 1988
Engine: 360
Default Sending unit removal
I recently acquired an 88 power ram with 38k miles one owner truck. It's sat for nearly 20 years and it runs great when you fill the bowl on the carb but dies when it runs out. I found the issue when I dropped the tank the lines are rusted off an I can't get the sending unit to turn to come out any advice?
Sponsored Ad
Register to remove this ad.
Myarrowshoyt is offline   Reply With Quote
Old 06-02-2015, 06:05 PM   #2 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
i have usually used locking pliers and a hammer. not the greatest way but i don't know of any other way to do it. if you run the vin you can find out what size fuel tank you have so that you can get the correct sending unit for your truck. just put your vin in the box labeled vin and it should bring up your build sheet. i have been told it should work for 88 and newer vehicles but the oldest vin i have run was a 89 so i don't know if it is true or not
Support Home Page
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is offline   Reply With Quote
Old 06-02-2015, 07:23 PM   #3 (permalink)
Ram Year: 1988
Engine: 360
Default
It's a 30 gallon tank. I'm gonna try what you said so thanks I appreciate it!
Old 06-02-2015, 07:58 PM   #4 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
i have done 3 gas tanks that way so far. i did kind of mangle the plastic ring a bit but it still does the job. if you want to replace the sending unit i am pretty sure you can get them from dodge. 4075474 should be the part number for the one you need and only cost about $100. now if you got some 3/8" and 5/16" fuel line sitting around you could probably redneck fix the sending unit
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cannot Find Fuel Sending Unit for 84 D150 Yoox_II General Discussions 1 01-30-2015 02:32 PM
Coolant Temperature Sending Unit Bravo_Zulu Engine & Performance 4 03-17-2014 02:38 PM
Second O/P sending unit location Rick2002 Engine & Performance 1 11-19-2013 06:20 PM
sending unit oldblue Tech Info 7 10-30-2012 08:05 PM
OP sending unit question Viper21700 P Pump 1 05-13-2012 08:05 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
