Moe's 87mm Throttle Body
Status
Not open for further replies.
Bfazona
Harmans, MD
87mm throttle body removed from my 2015 Ram Sport. This only had a few thousand miles on it before I traded my truck. $250
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
What are the perks for a throttle body spacer?
Not a spacer.
Spacers are worthless if you aren't using them as an insert for Nitrous.
This is a ported (enlarged) factory throttle body.
Factory contour does not give full diameter at WOT. By machining you get 5-8% more diameter at WOT without ruining your idle or needing customized tuning.
Status
