Ive went through numerous threads and checked the more likely of issues. None have work. Got desperate, and started my own thread.
Issue started out with a whining sound in the back end. All speed based. Non dependant on RPM or brakes. So to me, obviously it's a wheel bearing. Right?
So made a day of it. Checked all the tires. Noticed a pretty significant amount of play in the back passenger tire than the others. Not sure why the back axles are allowed to slide at all... but guess that's Okay? Note:The dif fluid was really dirty. Changed only the outer bearing. It did seem to have a little damage. I know one should change all 4 rear bearings and seals, but it's Christmas time. Being cheap. Put it all back together after a good amount of cleaning... Started up fine. No codes. No errors. Still whining. Not as bad. But its still there. Any suggestions?
I've read that it could be the torque converter a million times... But it really sounds like it's in the rear end.
Some background info... 2013 dodge ram 1500 bighorn 2wd. Currently at 107k miles. Pretty confident I changed out all factory parts. Well. Part.
Also, after replacing all that, I randomly get a "service anti-lock brake system" message on my dash. I've read that bumps and moisture can mess up the sensors. I babied the entire caliper/brake and hub, so i can confirm it didn't get any physical damage to the wires or sensor. But it was extremely foggy and humid. Anything metallic and cool got condinsation on it. Are they really that sensitive?
Bought the truck for making consistent medium heavy hauls. I can't risk having a load of building materials parked on the side of the road.
