RamInfo
My new Ram started marking its territory in my garage this week. Last oil change was at dealer, 3k miles ago. Crawled under the truck and found filter was loose, tightened it hand tight as best I could-it's tough to reach without a lift or a pit--and will be taking it to the dealer to be checked tomorrow. I assume this is a fluke but don't understand why it was ok for 3k miles then started leaking?
As long as it's in there, I'm going to have them check the wind whistle on driver's door--it's the door, not the window as I tested it with painter's tape. I see a lot of comments on wind noise here in the forum--can the dealers actually get this licked or does it just keep coming back?
Last item for dealer to check is my fold-up center console. It jiggles at every small bump and the latch handle has an annoying rattle. Nature of the beast, or ?
Thx,
DG
Thx,
DG
