Alignment???
VB712
Maxi_built
Va Beach
I put 2" rear drop springs on my truck. A local shop is now telling me I need a front end alignment after lowering the rear.
Doesn't make sense to me.
Anyone? True or not?
BBRAM2500
stony plain Alberta
It is because by dropping the rear you further change the rake on your truck same if you raise the front or rear you technically need an alignment
VB712
VB712
Maxi_built
Va Beach
Does lowering the rear really change the front enough to where it needs a new alignment? Lowered the rear 3,000+ miles ago and haven't noticed any tire wear and it drives the same as before I lowered it.
VB712
VB712
Maxi_built
Va Beach
Well. My truck drove pretty straight but decided to drop it off this morning for an alignment since everyone said it's needed once you lower the rear. Needless to say, the front was all out of wack!
Kab
Did that when I did the springs a few months ago. Thanks for the tip though!
What is all involved with just a 2" rear drop? I'm wanting to do one on my 16 1500 4x4 but honestly I've never lifted or lowered any vehicle I've ever had. I appreciate any information, thank you
VB712
VB712
Maxi_built
Va Beach
Just swapped the rear springs and got a front end alignment. Only took about an hour with basic tools to swap rear springs.
Kab
What company did you get the rear springs from?
Kab
Mcgaughys
What year is your truck? I looked at their stuff and didn't find anything for a 2016 4x4. I must have over looked it maybe. Never done this stuf before.
charonblk07
Calgary, Ab
F1-A forged 349ci
They don't list anything for a 4wd but the rear springs are the same and work great. If you get their 2" rear drop springs it's about a 2-2.5" drop on the rear depending on cab size on the 4wd.
Kab
Is there anyone who by chance sells 1" drop coil springs? I want to lower the rear but I also have a 7k camper I pull and with my weight distribution hitch I still have about 1" rake hooked up.
charonblk07
Calgary, Ab
F1-A forged 349ci
Check out Crown Suspension
jag1886
Boise Id Gods country
Demi 5.7 S&B CAI, flowmaster merge collector, Gibson cat back, oil catch can, 87
I cut a coil off my stock rear springs (lowered about an 1") and noticed a few months later that the front tires where scuffing on the outside and had to have it realigned. Don't know if that had anything to do with it but it wasn't doing it before.
Reactions: Kab
Kab
Yes, lowering the rear changes the front alignment
AzCats
Portland OR
2014 1500 CC Laramie
This thread was a big help. Thanks everyone
Jems007
