12BlackRam
- Apr 3, 2014
- 18
- 3
- 2012
- Hemi 5.7
Back in May I had the Rough Country 2.5"/1.75" lift level installed on my truck. 2012 Crew Cab 4x4 w/ 305/55 R20 Mickey Thompson Baja MTZ. I'm very happy with the ride and stance of the truck since the install.
Anyway....here is the question.
I have put right around 4,000 miles on the truck since the work was done. I have noticed that my front tires are starting to cup. Any suggestions or ideas. An alignment was done at the time of install. I haven't had time to dig into this problem, yet. But I was wondering opinions on what to look for....Alignment, toe? Tire pressure? Ball joint?
The tires are load range E and I am running 35psi? What pressure are you guys running? Did you stay with factory pressure or increase when you change the tires to load range E?
It could be an alignment issue, but if the toe has changed isn't that related to a suspension issue?
I know some others have reported ball joint issues, but it was my impression that 2012's and up weren't having the issues.
Shoot me back some ideas.....
Thanks!
Thanks!
