Custom Retrofit, FXR into Quad headlights. FINISHED PICS on PAGE 2
* * * COMPLETED 11/28/16, PICS ON PAGE 2 * * *
So I decided to dive head first into this project yesterday. I want to start out by saying that I know there are other options like buying factory projectors and swapping the FXR or Retro'ing the quads with the MiniH1's, etc. I am aware of all that, but its not what I wanted. I really like the way the quads look with the switchback halos, so I decided to make it work. I spent damn near an hour to get one headlight open. I've opened a few different headlights over the years and I've never experienced such a difficult time as I did with these lights. I let them bake for 15 minutes at 275 degrees and they still gave me a hard time.
I ordered a pair of FXR's from JJ and they will be here tomorrow, but I figured I should start building a prototype bracket today, so I grabbed some scrap steel and went to town. The stock reflector is not used in any way other then to take the black clips off that attach to the mounting "pegs."
I drilled out a piece of 1/2" steel round bar and threaded it for 6mm x 1.0 screws so I could attach the black retaining clips. The other piece is 3/4" tube with a 16 gauge wall thickness.
I had to trim the inner headlight bezel a little to fit the bracket. In hindsight, I could have notched the tube where it attaches to the flat piece into a half circle shape and possibly avoiding the notching, I'll have to try it on the other headlight. I just made some rough cuts with a cut off wheel on a dremel. I'll clean them up and paint them black before I finish.
Thats all for today. Once the projector some in I can test fit one and work on the "real" brackets, which I intend to make out of aluminum. The flat part of the bracket isn't really straight, it was a pre-cut piece of steel I had laying around that just happened to fit in the light, so if it looks crooked, thats because it is, LOL.
