Upon using the almighty search function, I find that it is possible, but not stock on my truck. I pulled the back seat off and found a couple ways to make this happen that I came up with, and one that I pulled off of another thread. Here are some pictures I took of the seat and how it is attached.
The seat laid down:
The Hook on the back of the seat:
and the attachment point on the wall:
The first solution I found off of another thread is to put spacers under the seat so that when the rear seat is folded up, the Hook comes out of the metal loop it attaches to. This sounds like a perfectly good plan to me, until I want to just raise the seat bottom up, at which point I am thinking neither part of the seat will stay up. Plenty of solutions i can think of, such as a latch to hold the seats up, but what are y'all thinking?
Second is either cut more off the Hook off and attach a sleeve around what remains of it attached to a pull tab that will allow me to unhook it, or cutting the Metal Loop itself and then doing the same type of thing. Thoughts?
A diagram of that last part:
The Black Part is the Hook that is already there
the Red part is the sleeve
and the blue part is the spring
Thoughts?
The first way is by far the simplest and least invasive and I might try it just try for the hell of it anyway, due to MDF being so cheap
