My 2016 Laramie has the full center console. On bumpy roads it rattles like crazy! Anyone else have this problem? How did you fix it? Did you take it to the dealership? Or did you fix it yourself?
Try getting yourself some camper foam. It's a foam with adhesive on one side. It comes in rolls. You can take off chunks and put it in places to help with noises and vibration. As far as the center console, if you want to fix it yourself, it's going to be a lot of trial-and-error because that kind of stuff can be a huge PITA to track down. Might not hurt to let the dealership look at it, if you trust their service department, but don't be surprised if you get the "Couldn't recreate the issue" excuse service departments so famously use when they don't want to invest the time into fixing the issue.
I would play around with the foam, figure out which pieces are rubbing or possibly making contact, shove a little foam between them, then go out and drive and see if the issue goes away. Thankfully my console is quiet enough it doesn't bother me, but I had to put quite a bit of foam under the dash on the driver's side, and in between the wall panel on the passenger side that was hitting up against the plastic where the passenger seat bends.
Rattles are a major PITA, best of luck. Hopefully someone else has something more specific. If you find a fix though, be sure to let us know!
