Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Engine & Performance
I feel my RAM slower and "heavier"
This is a discussion on I feel my RAM slower and "heavier" within the Engine & Performance forums, part of the 4th Gen : 2009 - Present category!
Hi everyone! I just joined this forum to seek some advice, I thank you guys in advance I have a ...
Like Tree17Likes
Sponsored By: Moe's Performance
Reply
Old 07-15-2017, 03:10 PM   #1 (permalink)
Ram Year: 2014
Engine: V6 Flex Fuel 3.6 Liter Pentastar
Default I feel my RAM slower and "heavier"
Hi everyone!
I just joined this forum to seek some advice, I thank you guys in advance I have a 2014 RAM 1500 Tradesman with the V6 Flex Fuel 3.6 Liter Pentastar and I am a little concern about the performance. I did a couple of upgrades to my RAM like 3 months ago: first I installed a Spectre CAI which I really like, I feel my truck has a better throttle response and I love the sound, and then a month later I replaced my 17"s with these 20" OEM black wheels (which changed the look completely) and right after this I feel like my truck is slower, like I'm always hauling something in the highway.
I set the cruise control to a certain speed (72-75mph) and looks like is hard for my RAM to maintain the speed; its even worse when Im going on a little uphill I get high rpms trying to maintain the speed set, I rather to just cancel the cruise control and control the revolutions myself.
I went to the Dodge RAM dealer and asked them if there is any adjustment that it need to be done after I changed my wheels but they said No, it should be good since it is about the same size and width.
Have any of you experienced something like this?, the feel like your RAM is not responding as it suppose to What do you guys recommend me to do or to check?
Thanks!
Sponsored Ad
Register to remove this ad.
Christian1500 is offline   Reply With Quote
Old 07-15-2017, 03:14 PM   #2 (permalink)
Ram Year: 2017
Engine: Hemi 5.7
Default
What tires do you have? Some tires have higher rolling resistance.... You could try adding a couple psi.
Also, if the new rims/tires weigh more, you'll definitely notice a difference.
averageguy likes this.
CrispyBacon is offline   Reply With Quote
Old 07-15-2017, 03:56 PM   #3 (permalink)
Ram Year: 2014
Default
They are Goodyear Wrangler SR-A P275/60R20 (before P265/70R17) and they are little worn out I will need new tires pretty soon. I can try adding a couple PSI. Thanks!
Old 07-15-2017, 04:59 PM   #4 (permalink)
crash68's Avatar
Ram Year: 2015
Engine: 3.0 EcoDiesel
Default
By going to a larger diameter wheel, you essentially changed raised the effective final drive ratio. The 275/60r20 are 33" the 265/70r17 are 31.5" tires.
Your engine rpms are lower for the same speed, hence why it feels sluggish. This is why lifted truck with tall tires put lower gearing to compensate for the larger diameter tire.
That dealer is full of BS, they can change the what tire size the truck has(since it is a factory size) to correct the speedometer and odometer, but it won't do anything for performance.
Christian1500 likes this.
crash68 is offline   Reply With Quote
Old 07-15-2017, 05:57 PM   #5 (permalink)
Spearsy's Avatar
Ram Year: 2017
Engine: Pentastar V6
Default
I have a 2017 with the exact same setup. I'm already running the same tires and wheels (275/60r20) as they came stock. I could see some power diminishing but I have never felt my truck to be underpowered tho. I have 3.55 gears. Do you know what gears you are running?
Spearsy is offline   Reply With Quote
Old 07-15-2017, 07:12 PM   #6 (permalink)
Ram Year: 2014
Default
Yeah I'm not sure what gears are on my truck, I will need to find that out. When going uphill (there is a few where I live) I feel no power when I press the gas pedal I just see the rpms going up, I'm not sure if this is normal for a V6 engine, I can't recall if it was like this before the upgrades.
Also they changed the oil on my RAM like 2 months ago and they used Synthetic, I have 35k miles on my truck, I'm not sure if this has anything to do.
Old 07-15-2017, 07:23 PM   #7 (permalink)
Ratket's Avatar
Ram Year: 2014 2500
Engine: Hemi 6.4
Default
I can't speak to the pen star- my work truck is a " extremely over loaded " 3.7l Ford V6 in a F150 and I have to rev the shit out of it to get it to move. But since u are essentially in stock form this shouldn't be an issue for you- can someone post the vin link so he can punch his vin in and see his gears? I can't find it ATM. But when ur truck down shifts you should definetly feel it move and see that speedo climb.
__________________
2014 Ram 2500 mega cab Big Horn 6.4 4x4 3.73's Factory 20's wrapped in a 33" maximum steel/ Factory cab length running boards/ UnderCover Flex Tonneau cover/de badged/tinted over factory tint.
Ratket is offline   Reply With Quote
Old 07-15-2017, 10:11 PM   #8 (permalink)
Ram Year: 2013
Engine: Hemi 5.7L
Default
Surprised nobody has mentioned that the 20's likely weigh significantly more than the 17's. Add that to the small increase in diameter and you may have the reason for the perceived sluggishness.
Markcuda and Christian1500 like this.
RysRam is offline   Reply With Quote
Old 07-16-2017, 02:02 AM   #9 (permalink)
Ram Year: 2016
Engine: hemi 5.7
Default
You went to s larger diameter tire. You speed is off as well as your shift pattern. The pcm needs to be flashed. In other words. The truck needs to be told you have later tires now.
huntergreen is offline   Reply With Quote
Old 07-16-2017, 02:54 AM   #10 (permalink)
Ram Year: 2015 CC Sport
Engine: 5.7
Default
all these answers are correct.
to make it simple, its takes more power / tourque to turn a larger tire/wheel. Youe v6 motor is now being asked to do more with the same amount of power
If you took your truck with 17's and raced from a dead stop the same turck with 20's, the truck with the 17's would win.
your truck is now in fact slower and more sluggish.
joneseysr6 is offline   Reply With Quote
Reply
Tags
cai, rpm, wheel
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
3" Front and 2" rear "leveling" question CamdenRam Lifted 20 01-01-2017 06:09 PM
Thoughts about "truckonator" or the "tornado" intake fans jschreiber94 Engine & Performance 16 08-06-2014 11:58 PM
"Hash marks" or "muscle stripes" rileybrennan Exterior 31 06-21-2013 02:25 AM
Help me feel better about my new "mod" cheapbeater Exterior 30 07-13-2010 05:14 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
