Inlet for exhaust tip
Bighorn 4 Life
Blue Springs Missouri
I have a 2010 Ram 1500 Big Horn. It has duels so they are 2.5"? Do I need to get 2.5" Inlet exhaust tips for them to bolt on? I am looking at Gibson 5" tips.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Not sure, you can pull tip off easily, and measure to be sure. Its just bolted on and a small tack weld. Takes 2 minutes to get off.
Bighorn 4 Life
Bighorn 4 Life
I measured it. It's definitely 2.5". I was just wondering if the inlet of the new tip needs to be 2.5" as well or bigger?
Graygoose
Oklahoma
Convert, for now.
small
ahh, well it should be slightly to go on if its a bolt on.
Graygoose
Oklahoma
Convert, for now.
small
Ok cool deal. I will get the 2.5" inlet. Thank you very much.
you bet, worse case if they don't slide on, stop by a muffler or pipe shop they can flange it for you.
