Space Monkey
- Sep 6, 2015
- 323
- 184
- Southern Illinois
- 2010
- 5.7 Hemi
Ok.. so, a quick run down here.. I had started another thread, "My Maggie Breaks Wind.. WTF?!", a while back to try and see if any of you had encountered an exhaust noise I had been hearing.. and to see if anyone knew why I was hearing it.
Towards the end of the thread, a member had mentioned taking his truck in to have a noise checked out which turned out to be his MDS lifters. Which in turn, caused me to make an appointment with the dealership to have mine checked due to a 'ticking noise' I had been experiencing which arised around the same time my exhaust started 'farting' while it shifted at red line.
Link for the other thread:
http://www.ramforum.com/f44/my_maggie_breaks_wind_wtf-76420/
So...
I've been having a 'tick' on the passenger side of the motor on a cold start up, and while driving 20-30 with MDS engaged. It's the same exact noise.. I've tried different oils (conventional, synthetic blend and straight synthetic), none got rid of this 'tick'. I am familiar with the 'Hemi Tick' and this is not it..
So.. I took the truck into Dodge this morning. I explained to them exactly what was going on (cold start tick, cruising tick and the exhaust 'farting') and had the service manager and tech ride along with me to show them the 'tick' noise I've been hearing. I obviously couldn't show the the cold start tick as I had just arrived.
While on the drive, of course I heard the 'tick'.. however, the manager and the tech both said they couldn't hear anything..
Seriously?..
So I asked them if they both listened to rock music too loud as kids, because this 'tick' could be clearly heard. They still claimed to not be able to hear it during the whole drive.
We returned to the dealership and the tech asked me while he was walking around the front of the truck if I have a 'tick' during a cold start up. I told him yes, and that I've explained that already.
He said that if I have the same noise at the first start up, after its been sitting, AND while driving, that it couldn't be the MDS. He continued to explain that while it's idling, MDS is not engaged and that the truck is running on all 8 cylinders. (Makes sense)
He continued with a claim that he hasn't heard of very many issues with the MDS system at all, but that when a customer came in for a 'tick'.. he HAS changed quite a few broken exhaust manifold bolts on the passenger side at the end of the manifold.. towards the back of the motor...
Interesting..
So, he told me to take it home and get underneath it and pull on the heat shield covering the manifold. If I can move it, that I have a broken bolt..
Sure enough, I did what he recommended and found a broken bolt.. It was the very last one at the end of the manifold on the passenger side.
This may have been the issue all along..
I guess, in theory, it would make sense as to why my exhaust was 'farting'.. I assume, do to the difference in pressures because of the manifold not being completely sealed properly to the head.
Gonna get everything together this week and if time permits, I'll fix it this weekend.. Hopefully, this takes care of all issues together. If not, it's back to the drawing board.. and the dealership.
I figured I'd share this experience with ya'll here in case any of you encounter this 'tick' as well. Check your manifold bolt first. May save you a trip to the dealer and time off work.
I will update this thread when I get the bolt changed and let ya'll know if it remedied the issues.
So...
Seriously?..
Interesting..
