Synthetic Oil
Oil of Choice
  • Castrol Syntec/Edge
    Votes: 236 8.5%
  • Royal Purple
    Votes: 327 11.8%
  • AMSOil
    Votes: 400 14.4%
  • Valvoline Synpower
    Votes: 160 5.8%
  • Mobil 1
    Votes: 994 35.8%
  • Other
    Votes: 662 23.8%
  • Total voters
    2,779
Wild one
14 Sport
Hopefully this works,and there's a picture of the fluid level checking instructions that came with my transmission
R.L.K.
Bristol , Tn.
Not working for me , maybe try again as I'm very interested in printing a copy [emoji1303] thanks!
Wild one
14 Sport
Looks like it only worked for a few minutes,i copied it from my post on facebook.If you check out the other thread I just started,it'll link you to the instructions posted on facebook. If you're not a member of facebook,you're probably screwed as I don't have a photobook account,and have never successfully managed to get a picture on here.If anybody wants to copy them off the facebook posting,and post them here,please do.
Rick
https://www.facebook.com/photo.php?...QbXByDKYFdJmf7eiRRcTxmfSsdEZk8P1spROFll&ifg=1
huntergreen
God knows the dealership ain't gonna check it. It says right on their paperwork that they only check transmission fluid level if it has a dipstick.
I hope that isn't every dealer.
R.L.K.
Bristol , Tn.
Rick
Awesome !
Thanks again [emoji1303]
Hemi395
Cape Cod MA
"Raise the vehicle.
Stand on your head.
On a harvest moon, pull the fill plug.
Start the vehicle.
Remove the front axle.
Tilt the vehicle at a 32.7463° angle (has to be exact).
Shut off vehicle.
Start vehicle.
Raise the rpms to exactly 2273 (no more).
Scratch your balls with your left index and middle fingers.
If fluid runs out of fill port, fluid level is correct. If not, the preceedure will have to be attempted again on the next harvest moon.
Shut off vehicle.
Reinstall the front axle.
Return vehicle to level angle.
Lower vehicle."
U&A
Michigan
2016 3500 SRW
6.4 HEMI
"Raise the vehicle.
Stand on your head.
Start the vehicle.
Shut off vehicle.
Start vehicle.
Shut off vehicle.
Lower vehicle."
Best post of the week!!
[emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
Wild one
14 Sport
"Raise the vehicle.
Stand on your head.
Start the vehicle.
Shut off vehicle.
Start vehicle.
Shut off vehicle.
Lower vehicle."
Damn near fell off the chair Hemi,i agree,this is the funniest and best post I've read in awhile,lol
Wild one
14 Sport
LOL but in all seriousness, that has to be the most complicated fluid check procedure they could've possibly come up with.
It actually sounds worse then it is. I flushed my cooler and heater assembly manually then did 4 pan drops and fluid changes just to get everything flushed out.By the 4th pan drop,i was flat broke from buying fluid,but I could do the fluid check in my sleep,lol.The stock pan is definitely easier to drop then the PPE pan.The extra depth of the PPE pans sump,makes it slightly harder to R&R around the exhaust,but i'm a firm believer in the PPE pan.Both a buddy and I figure the pan takes a good 5 degrees out of the tranny temp in the summer on our 14 4X4's.My truck's a pavement princess and is parked now till next spring,so I can't say how much it'd drop the trannies operating temps in the winter though
Zack02
Unplug coil. Loosen 2 captured screws on coil. Pull coil out. Thin wall deep well socket (wit da rubber innards) to remove plug.
Obviously compressed air to blow everything out well before disconnecting/removing each thing.
A little late to party...I found changing my plugs were the typical PIA pugs are; not sure how much different the 6.4 really is... It wasn't bad, just not sheering off the threads was the worst/ scary part. I had 55k on my factory plugs when changed..No noticeable throttle or MPG change. I think you'll be fine to wait 'till spring. lol I'll change mine again this spring since that'll be ~30k on these.
I think you are right. It recycles well. Dump it anywhere and it hurts nothing. Make it out of sand. All good!
Have you seen the documentary "Sand Wars?" Sand is getting up there with fresh water and oil in terms of value...
Burla
2010 Hemi Reg Cab 4x4
Bottom line first, look how beneficial it is to have over 200ppm moly. This is more complex because science studies don't think like most of us do, there are many things at play here primary and secondary zddp, and the moly the tested was not tri nuclear moly but dn moly the type in redline, and the result was the optimum moly level was between 200ppm to 700ppm moly, added with 1,000 ppm zinc. Just maybe that is why redline quiets so many ticks, it's not one plate but two. Not all zinc was equal, remember a while back I posted that as well. They tested 3 types of zinc. Moly plate with the right zddp on top = low coefficient of friction.
Zinc needs moly? Does moly need zinc? Turns out yes, they need each other, which really doesn't bode well for guys running non moly'd oils. And, in this report an optimum zddp level is 1,000 ppm. At high rates of mo/zddp they compete for the surface, but mo wins. Once again more evidence it takes time for the moly to plate, but this study may suggest something of a double plate when moly absorbs in the metal first, zddp compliments that by having a sacrificial layer on top of that. I'll just post the summary.
The frictional characteristics of oils containing molybdenum dialkyldithiocarbamate (MoDTC) together with zinc dialkyldithiophosphate (ZnDTP) were studied with a reciprocating roller-on-disk tester. At a Zn concentration of 1000 ppm there was an optimum Mo concentration for friction reduction depending upon the alkyl group of ZnDTP. The friction was affected significantly by ZnDTP type at low Mo/Zn ratios while the extent of the effect of ZnDTP type on friction became small at high Mo/Zn ratios. For a combination of MoDTC and ZnDTP with primary C8 alkyl group, the preferential formation of a film containing products derived from ZnDTP was delayed appreciably due to competitive adsorption of MoDTC onto the rubbing surface. However, this contributed to a more effective friction reduction because the ratio of products from ZnDTP producing a high friction in the outermost surface film became lower during the initial period of the run.
Look at the coefficient for friction...
Burla
It's safe to say as fact, if you don't have moly in your oil unless you have a competitive replacement for it, then you simply have more friction in your engine.
