Got A New Mod Today
shadow11
Banned
Houston TX
Added some stripes to the truck today thanks to The Assassin. I think it looks good. I screwed up the passengers side so I got to get a new one for that side. Few bubbles but they will come out in a few days. Let me know what you guys/gals think.
Bad Habit
Land O Lakes
Modded 4.7l
what did you pay for that? i been wanting to do this and i just been putting it off and it looks great, i need some in flat black....
EJM05
Somers, CT
440 Big Block
Looks badass. I want to do this aswell. When the spring comes I will. No mod money right now cause I bought a bushmaster AR-15
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I didn't know he did vinyl work..........hmmmmmm
truckin151
2013 sport
Its not bad, but something doesn't look quite right with it, like the strippes are not on straight.
shadow11
shadow11
Banned
Houston TX
They are straight. I have to trim them better at the hood and fender gap if that is what you are referring to.
blackshadow
chesapeake va
a trick to do vynal is to use some soap and water in a spray bottle and spray the vynal and the paint then you can move them around where ever you want and the you can also use a squeegee so get the bubbles out works like a charm.
shadow11
shadow11
Banned
Houston TX
Exactly what I did :). Also another tip I learned is to put some rubbing alcohol in the mixture to so it makes the vinyl stick better instead of just constantly sliding around.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I will have to try mixing in the rubbing alch next time I have to lay down a bigger decal. I have done the soapy water solution key is to do it just enough to move and not to keep it sliding like its on eel ****.
AParrette
St Augustine, FL
1997 Pontiac Grand Prix
3.8L SUPERCHARGED
where did you get it at? and why such a small number?
