Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Exterior
Exterior
No brake or turn signal lights
This is a discussion on No brake or turn signal lights within the Exterior forums, part of the 3rd Gen : 2002 - 2008 category!
Hi all, this is my first post in this forum. Got an 07 Ram 1500 hemi 5.7l I have no ...
Sponsored By: BAK Factory Outlet
Reply
Old 12-28-2016, 07:25 PM   #1 (permalink)
Ram Year: 2007
Engine: Hemi 5.7l
Default No brake or turn signal lights
I have no brake lights or rear turn signals.
Tail lights do light up.
Reverse lights work.
And third brake light over cab works as well.
I checked and replaced all fuses.
Replaced all bulbs. No luck.
Front turn signals work fine although I get the fast flash. When I turn on hazards though, the front turn signals are slow not fast.
Replacing brake switch tonight. Then multi function switch on friday. Anything else to try? Is there a ground wire for the rear lights that could be out?
Sponsored Ad
Register to remove this ad.
Brad141987 is offline   Reply With Quote
Old 12-29-2016, 01:47 AM   #2 (permalink)
ms8091's Avatar
Ram Year: 2012
Engine: 4.7L
Default
I'm not sure if in yours if the turn and brake are the same bulb but if so, there is a good chance it's the turn signal switch in the column. Happened to me on an older Ram (1981) and the old timer next door was a semi service tech. After I screwed with it for hours, he diagnosed it in less than 5 minutes.
ms8091 is offline   Reply With Quote
Old 01-18-2017, 12:14 PM   #3 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
Had this issue before on my Ram. Ended up replacing the tail light circuit board and fixed my issues.
Dorman - OE Solutions Tail Lamp Circuit Board, Left OR Right 923-030: Advance Auto Parts
__________________
Bolt ons, Cam, Heads, Stall, Gears, & 150 shot
11's on the Bottle
My Compilation Video | 1/4 Mile 11.59 @ 118mph video
hemi_loredo03 is offline   Reply With Quote
Old 01-18-2017, 10:58 PM   #4 (permalink)
Ram Year: 2004
Engine: 4.7
Default
If your truck has been lowered, you might have damaged inside of fender wells and cut into wires. Happened to me and messed up wires that run on the drivers side. Had no back lights at all. After replacing everything from bulbs, to switch under dash, I saw wires were exposed and I just used electrical tape to fix. Been good ever since.
979dodge is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Right Brake light/Turn signal out Boomer79 General Discussions 1 02-14-2016 11:20 PM
HELP! Front left turn signal comes on when brake is pressed greychevy Exterior 16 09-18-2015 10:21 PM
brake light/ turn signal issue mverps Audio & Electronics 0 03-13-2015 10:21 PM
LED Turn Signal/Brake problem USMC1188 General Discussions 13 04-05-2014 11:34 PM
Right trailer brake light and turn signal inoperative RainMaker Audio & Electronics 4 08-26-2012 01:14 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
