LS5DodgeRam
- Feb 17, 2013
- 793
- 115
- South Florida
- 2004
- 4.7L v8
So I have had my truck for a couple of years, and it has been through some bad moments although not horribly bad. I got all my speakers replaced with larger speakers, right after I just got fresh tint on the windows. this was about 2 years ago. The idiots at the shop didn't put the spacers on the speakers when they should have, which resulted in my entire window falling into the door panel and completely off the tracks. this screwed up my tint (ill get fixed eventually), and then I went back to the shop. they put the window back in the tracks, but again left the spacers out (this is why i do not like taking my truck to shops). I put the spacers in myself and tightened all the window frame bolts and it hasn't happen since.
Then the same summer I got this work done, my sister crashed my truck with minimal damage. All I had to do was replace the bumper, grill, and the hood which I went with the srt-10. now, my passenger side door has rust on it, throught the door as well the rust started where the side impact bar inside the door is welded to the door. this leads me to believe that the crash and the knocking of the window inside the door, has caused the weld to break at that point.
now that the long background is done... my question is that if any has had anything similar to this problem.... How much do you think it would cost to repair this, and how should I go about doing so? should I buy a whole new door? or just cut around the rust and reweld the door with a new piece of metal and paint and blend the door?
