kewpie79
I put in a new switch, same results, full dash and no start. It does not turn over, just a loud click. As a side note, my chimes come on whenever the door opens, even with no keys in the ignition. Any ideas?
Another thought and you gear heads will know better. if it is coming from the starter could it be the starter solenoid ? Can someone rap on the starter with a hammer while trying to start the truck ? We had a truck at the auction that had that done and it started, guess jolted the bad starter? New starters can be bad, Have you removed the New starter and tried it off the truck to be sure it works and is not jammed in theClick is coming from starter. Will not start in neutral. Only thing left is the neutral safety switch?
