I ohm'd the pins that match the empty slots 17-18-19. The run all the way to the tailgate. So it does look like the radio harness is all I need!PM's sent. Thanks for the assist Ronnie. I've got several Harnesses to make and I don't want to disappoint anyone. Being out of town for 3 weeks didn't help.
Hopefully he can trace out the 4 connectors and id exactly what segment he's missing. Also needs to id what Connector he has at the brake pedal, i315 or Inline-Body IP Connector?
M² Mods - From my non Flammable S7!
Read post # 10 and it's references in this thread Sir .Alright. I'm sure this has been covered. But as I'm on mobile it is very hard reading through 68 pages of posts... I have a 17 express. Has the uconnect 3.0 with hands free and the such. Just bought a 2016 uconnect 5.0 to swap so I can add the backup camera. Where do I need to go to find any parts? The camera and the harness to connect it? Where do I check to see if I have all the proper wires already so I can just swap the harness out for the camera harness.
The backup cam is nice on the RA2 5.0" Radio for sure !
Good luck !
Don't know what you mean by "Provisions" but it looks like you have a 2017 Ram 1500 truck so you "shouldn't" have the short extension/wearout connector that the 2500's and up do at the tailgate connector to worry about. It sounds like you may also have the chassis harness going up to the left front wheel well c322 connector. If that's true, you may only need the 3 wire "CAB" harness to complete what you have. I hate not being able to lay it all out for you, but post 10 has links to the 4 connectors and pictures to verify what you do/do not have in your truck. Please take a look and verify the wiring at ALL 4 points either visually and/or ohm out with a meter (Preferred). And post pictures of the back of the 4 connectors so people can help: i550 tailgate, c322 LtFrt Wheel well, i315/Inline-Body (near brake pedal), and Radio C1.Ok. So I'm trying to decided what all the jumble is. If my harness at the tailgate is fully populated in all 8 connectors then I shouldn't need to order the harness for the frame. Just the camera conversion. Am I correct? Never mind. Where can I find provisions to add the wire from the tailgate connector to the cab?
No idea. Hard to tell from the picture exactly where it is? Might be for the rear park sense. Hopefully someone recognizes it.Can anyone tell me what this spare connector is for ? can this be used for my tailgate back up camera connection to the radio?
Sorry provisions by harness with the pins already. And I traced it out to the cab harness. It's missing the 3 wire hookup into the cab and it looks like it's missing it to the radio as well
Crazykid,
Not sure where that 4th connector is that you are showing, but yeah it's not the same. Is it behind the left front wheel's plastic liner by the driver's floor board?
From what I see there so far, you are missing the chassis and cab wiring for the backup camera. Which means that piecing it together is not a cost effective option unless you scavenge all the tailgate parts for cheap.
You are likely better off getting the full Mopar kit with all the wiring and camera parts.
Look up behind the left front wheel's skirting, b/w the wheel and the bodyBehind front driver tire attached to the truck frame. I traced it forward from the tailgate. It is under the driver door.
Did you get this figured out Sir ?
The back up cam works with the RA2 5.0" & both the RA3 & RA4 8.4 " Radios .Ok this thread is big.......
Can't seem to find the proper part number to install a rear view cam on my '17 2500 powerwagon with a ra2 radio.
Also I will in the future upgrade my radio to a RA4/NAV will it still work?
Thanks
