coolbrzblu
Installed a new ati underdrive crank damper, after about 3 months and a couple hundred miles its leaking oil. Is the 4th gen the same as the 3rd gen, with only a seal on the timing chain cover?
If the cover should be removed to properly change the seal should I add a new cam at the same time since most of it will be apart anyway...
